Question on PC speakers
Discussion in 'Home Cinema Speakers' started by Ultima_Squall, Nov 13, 2004.
  1. Ultima_Squall
    Ultima_Squall
    I need help finding the right cable to connect my soundblaster audigy 2 zs digital out to my logitech z5500's optical input. The manual says digital coaxial cables or digital optical cables, but that's too vague for a newb like me. I went to the store and the clerk told me that i need a spdif plug for my sound card's digital out and then a toslink optical for my speakers optical input. Can someone recommend me a cable that's easy to find and that will work for me?Also will the following cables work for me: http://www.mycableshop.com/sku/TOSLINK15.htm
    http://www.mycableshop.com/sku/THINTOSMIN10.htm
