Question on Denon 2900
Discussion in 'Blu-ray & DVD Players & Recorders' started by geoffc, Nov 16, 2004.
  1. geoffc
    geoffc
    I have just purchased a new denon 2900 and am very pleased with the performance. However when I use the handset to display the time remaining on a dvd disc, both the player and the TV display the information.
    Does anyone know if it is possible to disable the TV picture from showing this information.
    Also - after a while you can smell the player if you are close to it ! (similar to burning - hot pcbs smell without the smoke !) Its only been used for about 4 hours in total - so I'm assuming this is normal during the burn in phase.
    Thanks in anticipation with any possible help,
    Regards
    Geoff
  2. ahin4114
    ahin4114
    Nov 1, 2004
    1,066
    Reading
    +48
    Hi Geoff
    Don't know about the On Screen Display, will have a look tonight, but regarding the burn in phase, I definitely had a light burn in smell when I first ran my 2900 in. The 2900 is renowned for running quite hot, so make sure it's not a component standing on top of it that's making the smell.
    Tony
  3. geoffc
    geoffc
    Thanks Tony, theres plenty of of space for cooling, so I'll not worry too much about the smell :clap:
    regards
    Geoff
