Question - Monitor Audio Soundframe
markkittle
Established Member
Joined
May 29, 2008
Messages
762
Reaction score
37
Points
141
Age
36
Location
northants
I'm after some wife friendly speakers and quite like to look/ spec on the MA Soundframe units.
I'm not sure if will do on or in wall yet, but have been offered some on walls at a good price. Also means may be able to use them bit in advance of a room build (won't be needing in-wall for a while).
Does anyone know the difference and if they can be converted at a later stage?
Looks like the in-walls have some brackets on the corners and on-walls hanger hook brackets on the back. I can't see a reason the on walls couldn't be put in-wall with some consideration (even if a custom bracket to support built into the wall) as sealed units and same size, etc.
Any help or views would e greatly appreciated!
TV Buying Guide - Which TV Is Best For You?
Back
