markkittle
Established Member
I'm after some wife friendly speakers and quite like to look/ spec on the MA Soundframe units.
I'm not sure if will do on or in wall yet, but have been offered some on walls at a good price. Also means may be able to use them bit in advance of a room build (won't be needing in-wall for a while).
Does anyone know the difference and if they can be converted at a later stage?
Looks like the in-walls have some brackets on the corners and on-walls hanger hook brackets on the back. I can't see a reason the on walls couldn't be put in-wall with some consideration (even if a custom bracket to support built into the wall) as sealed units and same size, etc.
Any help or views would e greatly appreciated!
