Question from Newbie
Discussion in 'AV Receivers & Amplifiers' started by rex8, Sep 18, 2005.
  1. rex8
    rex8
    Quick question. My Amp has one phono socket saying "sub out" but most subs seem to have 2 phono sockets, does this mean thay are not compatible? or do you just use one on the sub, left or right.
    Thanks for any help
  2. ozdvduser
    ozdvduser
    Apr 21, 2003
    170
    At The Track or Melbourne Victoria Australia
    +3
    You can connect it 2 ways [1] single RCA to single RCA to normally the L input on the sub, [2] Single RCA to 2x RCA to the L&R inputs on the sub. Some people say the 1->2 can be better than the 1->1, price wise a 1->2 is not that much more expensive.
  3. hedrick@rutgers
    [email protected]
    May 9, 2005
    57
    The sub is mono. Subs have two inputs because not all equipment has specialized sub outputs, so sometimes you need to connect normal L and R outputs to the sub. It just combines them. Dedicated sub outputs are single.
  4. rex8
    rex8
    Thanks for your help
  5. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    My sub has an in and an out phono, which is another possible config (for more than one sub...)
