Question for SteveEX - Rel sub volume level.
Discussion in 'Subwoofers' started by S H A D O, Aug 9, 2001.
  1. S H A D O
    S H A D O
    Mar 16, 2001
    10,369
    United Kingdom
    +1,737
    Hi Steve
    This has probably been answered before, seeing as your the man to talk to re Subs, Rels etc
    What volume levels do you have your Rel subs set at? i.e the volume knob on the actual subs
    I have a Q200 but the level is only set at around 1/5th. Ive heard its better to set the volume level much higher and use the processor/amp to control output. I have the A1se.
    Any thoughts??
    cheers in advance
    [ 09-08-2001: Message edited by: Hooty ]</p>
  2. Frustin
    Frustin
    i would also be insterested in this.
  3. Guest
    Gents.<br />I am not sure that there is a definitive answer to this, however i have always tried to set my sub's volume up so that roughly speaking the amp/processor etc lfe level is set at about mid-position of it's range (i.e if the range is -10 to +10 then i try and set it up so it's around 0 or if it's -10 to 0 then around -5). I do this simply so i have scope on either the side of the setting to either turn it up or down via the amp leaving the (tiresome) sub setting's alone as much as possible. It just so happens that this means the Rel volume pots are set to about 1 o'clock (just past half way). Personally i would have the pots somewhere near there anyway so as to let the sub's amps "breathe" a bit.
  4. S H A D O
    S H A D O
    Mar 16, 2001
    10,369
    United Kingdom
    +1,737
    Cheers Steve.
    Regards
