Question for PV500 wall mounted owners
Discussion in 'Home Cinema Buying & Building' started by Alan A, Aug 1, 2005.
  1. Alan A
    Alan A
    Jul 7, 2004
    186
    16
    I am STILL (noob!) trying to make a final descision between the PV500 and the 435XDE.
    One question that I hope some owners who have mounted the PV500 to the wall could answer for me?
    When on the wall, how easy is it to access the connections on the back of the panel?
    I am particulary thinking of accessing the Common interface module and connecting/disconnecting a laptop from the panel
    TIA
  2. ikon66
    ikon66
    Mar 22, 2005
    451
    Tyne & Wear
    +5
    you wouldn't have to worry about this with the xde as there is just the1 dual lead running from the mdia box to the panel, alot less hassle to wall mount
  3. Alan A
    Alan A
    Jul 7, 2004
    186
    16
    That's what was behind my question, as I have a concern about the ability to get t the connectors when tyhe PV500 is on the wall.
  4. stroppygoblin
    stroppygoblin
    Jun 2, 2005
    186
    depends on your wall mount....
    with the standard panny mount, it's pretty inaccessible. I got mine from RGB direct - their wall mount allows you to pivot the PV500 up from the bottom by about 20 degrees. This allows complete access to all the connections.
  5. Stampax
    Stampax
    May 6, 2005
    1,408
    Northampton
    +88
    Which wall mount was that - and how muc?
  6. stroppygoblin
    stroppygoblin
    Jun 2, 2005
    186
    I got mine free when I bought the PV500. However it can be bought speratly for 149.95 inc vat. The model number is RDPF1 - (Universal Wall Mount for Plasma Screens 32"-60")
    www.rgbdirect.co.uk - look in the accessories section
  7. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,176
    Norwich
    +796
    Would you not just buy a cable and put it in place so you don't have to keep plugging/unplugging at the plasma end?
  8. Alan A
    Alan A
    Jul 7, 2004
    186
    16
    Would you not have to keep moving the audio cables?
  9. stroppygoblin
    stroppygoblin
    Jun 2, 2005
    186
    Presumably you are connecting the audio out from the PC as well as the video connection?
    This will go to the PV500's Audio in socket(s). What else would you have using audio in? most other peripherals will be connected via SCART, thus carrying the audio signal in the same connector. The only exception I can see to this would be DVD using component. In which case you have a problem. Personally I would (and do) have an Amp and run all audio through that.
  10. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,176
    Norwich
    +796
    Use a splitter Alan if there is not a dedicated audio in for the VGA.
