Question for owners of widescreen TVs
Discussion in 'General TV Discussions Forum' started by the_saints, Sep 11, 2001.
  1. the_saints
    the_saints
    Several owners of Toshiba 36ZP18 TVs have complained of two vertical bands (one at either side of the screen approx 2" in from the side) that can be seen on programs with a light background eg football or on a blue screen. It seems the response from engineers is that this is normal for (large) widescreen TVs
    Have owners of other brands seen this phenomenon?
    [ 12-09-2001: Message edited by: the_saints ]</p>
  2. the_saints
    the_saints
    Any one????
  3. Doubledoom
    Doubledoom
    There was nothing present like that on my Toshiba 32MW7DB. There is also nothing on my current Toshiba 32ZP18P.
  4. torimusic
    torimusic
    If they're black bands then you are probably watching programs that are presented in the conventional 4:3 aspect ratio. Most widescreen TVs have a mode to eliminate these bands by stretching the image horizontally to fill the entire screen.
  5. retriever
    retriever
    I have the same Tosh telly as yourself, and, yes its suffers from the same faint bands going vertically down about 2" in from the edges both are a couple of inches wide, both are very faint and only seem to appear when there is a green background like a football or cricket field, there is no evidence of them on the blue sceen. I seem to remember reading a review of this telly a month or so ago and it mentioned about faint bands. I have never seen this on any other wide screen telly, so I would have to say its confined to this model
  6. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,626
    United Kingdom
    +2,233
    Its also present on my Jvc AV28WFX1, but you can only see them on certain backgrounds.
    So its not just your make & model of tv.
    cheers
  7. Andrew_arkless
    Andrew_arkless
    Sep 19, 2001
    181
    Essex
    +6
    I've just returned a Panasonic TX32PG50 as I was unhappy with the picture, one of the problems was dark banding at the 4:3 positions at either side of the screen which was visable only in certain circumstances, reading other posts in this forum it appears that this is a widespread "problem" on W/S TV's - The TV has shown this problem from new.
  8. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    None on my KV32DX20
