Question for GRAW (those who have it)
Discussion in 'Xbox Forums' started by Moogrose, Mar 8, 2006.
  1. Moogrose
    Moogrose
    Aug 5, 2005
    142
    you know that blue line around the screen, the edge - if you will, on my tv it doesn't completely show like in some screenshots i've seen, it actually goes out of the screen... its not there in its entirety. Is this normal, or do i have overscan issues?
  2. sirp
    sirp
    Jan 20, 2002
    902
    28
    Derby
    +55
    fits inside my screen m8
  3. syntax error
    syntax error
    Do you have your TV set to "zoom" or something? Make sure you are in widescreen mode basically.
  4. Moogrose
    Moogrose
    Aug 5, 2005
    142
    Yeah its on 16:9 on component on a LG26LX2R... so no zoom... it's starting to bother me a bit now. sigh.
  5. nero0410
    nero0410
    Jan 5, 2004
    12,669
    Weston Super Mare, UK
    +5,006
    Just wondering what connection that you are using? May help us have more idea's:thumbsup:
    tris
  6. Moogrose
    Moogrose
    Aug 5, 2005
    142
    component.
    Thank you to all who are trying to help here. Usually things look fine, its the first time i've noticed this, and otherwise the game looks good. its disturbing me though. could someone possibly post a photo of their dashboard on their set, so i can compare what you see on screen there to what i see on screen?
    again, thank you all.
  7. AVRocky
    AVRocky
    Jan 2, 2006
    2,205
    +88
    Maybe your 360 is setting the display to Widescreen instead of Normal?
  8. Moogrose
    Moogrose
    Aug 5, 2005
    142
    but it is a widescreen tv, and its set to 720p on the 360.
  9. nero0410
    nero0410
    Jan 5, 2004
    12,669
    +5,006
    Does it make any difference if you change the resolution to 480 or 1080?
    tris
  10. AVRocky
    AVRocky
    Jan 2, 2006
    2,205
    +88
    Mine is widescreen aswell but it looks much better on 'Normal' setting display instead of 'Widescreen'. When i changed it to Widescreen, the picture was stretcheeeeeeed.
  11. syntax error
    syntax error
    720p is automatically widescreen.
  12. krlock2
    krlock2
    normal things. make sure that the switch on the hd cable is set to HDTV.
    then double check in the dashboard that your settings are correctly set for widescreen 720p.
    then check that your TV is achieving 720p. normally remote controls have a button which says "i" for info, which will show the channel, input, and resolution.
    then check again the level of zoom, picture positioning (some lcds you can shift the picture around), and any other settings on your tv that you can think of.
    hope that helps
  13. syntax error
    syntax error
    Does seem very odd. Is your component going straight to the TV or via some component switcher?
    Whats the pic like if you switch it to 1080i?
    Also is there a settings option in the game to adjust the postioning of the picture?
  14. Moogrose
    Moogrose
    Aug 5, 2005
    142
    I'm not in front on the set so i'm gonna try changing up the settings to see if that makes a difference.
    But it is def on 720p via info on telly, and the settings are all right in the dashboard. switch is correct etc etc... went mad cheacking all those things yesterday.
    Its going straight to component, and 1080i looks pretty much the same
    it is also centered fine... just, well, too big i guess.
  15. Moogrose
    Moogrose
    Aug 5, 2005
    142
    Shifting the picture proves that there is overscan... i just don't know how to fix it!!?!
  16. dino2021
    dino2021
    Mar 9, 2005
    1,565
    63
    +138
    mine fits inside the screen also just for the record, good luck :)
  17. aftertaste
    aftertaste
    Mar 16, 2005
    1,177
    +89
    There aren't any options to change screen ration within the game, are there? I can't understand why you're having a problem.
    Does the HUD on any other game sneak off the edge?
  18. dino2021
    dino2021
    Mar 9, 2005
    1,565
    63
    +138
    none that i have seen
  19. Moogrose
    Moogrose
    Aug 5, 2005
    142
    Well, i figured it out to overscan in general on the xbox 360... even when i'm not in HD it overscans like a maniac... never noticed before as thus far everything had kinda fit... GRAW with its blue borders is the first game to show the overscan for what it is.
    If i move the picture about with tv settings (horiz and vert) i see the image i'm missing on the visible screen.
    its weird. and i hate it.
    Thank you to all those with suggestions and help.
  20. Dave
    Dave
    Jul 3, 2005
    11,496
    163
    +3,401
    I had the same problem with my panny PW7. Managed to sort it out by adjusting the screen size and position through the TV menu.
  21. safekidda
    safekidda
    Dec 3, 2005
    390
    Sheffield
    Are you using rgb scart? On my std tele when using rgb i can get some extra settings on my tele where i can change the horizontal size and position.
    EDIT: just read further up the post, ur using component, ignore above. You could try using vga, maybee this would help
  22. Malone
    Malone
    Mar 12, 2001
    1,859
    Ilkeston,Derby
    +70
    Trouble is VGA doesnt do 720p I dont believe?
    Matt
  23. dodger747
    dodger747
    May 5, 2005
    2,976
    Liverpool
    +209
    VGA can do 720p :thumbsup:
  24. Spoonman2
    Spoonman2
    Dec 28, 2002
    3,611
    137
    Ashford, Kent
    +581
    Yes it does! :thumbsup:
  25. jim_is_ere
    jim_is_ere
    Sep 29, 2005
    1,757
    Attleborough
    +270
    If your is not aligned correctly on GRAW. Then you will find that it is probably the same for all games - it's just you haven't noticed it!!
    cheers
    Jim
  26. Hi/zuum
    Hi/zuum
    Oct 4, 2005
    3,916
    Nottingham
    +400
  27. Hi/zuum
    Hi/zuum
    Oct 4, 2005
    3,916
    Nottingham
    +400
  28. -Hitman-
    -Hitman-
    Mar 21, 2005
    4,819
    Sector7
    +1,112
    Looks like you need to access the service menu on your LG and reduce horizontal and vertical size until the display shows no overscan.
    You may need to google search or look on the lcd section of this forum to find out how to access the service menu.
    Hope you sort it out!
  29. adrian3221
    adrian3221
    Dec 17, 2003
    718
    London
    +42
    Pictures fine on my PV500! :thumbsup:
  30. Hi/zuum
    Hi/zuum
    Oct 4, 2005
    3,916
    Nottingham
    +400
    Does yours look like the Panny52 LCD in the pic I post earlier.
