Question for fans of old crts - numbers/figures on an old vhf dial?
gubar
I'm making a 3d tv for an animation project. The images I have as reference are fine for the shape, but the text is a bit blurred - I'm not sure if it's just numbered or if there are symbols around the dial - anyone know? I can roughly see 1 to 6, but between 6 and 7 there is something else... also at the top I think between 11 and 0.
thanks if anyone can help,
gubar
gubar
Hi and thanks for the response.
Here it is:
I've got the model finished now so just adding textures.
cheers,
gubar
Chris Muriel
Well, from memory:
Band I (low VHF) was around 47-68 MHz and channels 1 to 5
Band III (high VHF) 170-230 MHz (now used for DAB) used (still uses in many countries but not UK) channels 6-12 or 13.
UK ceased using VHF TV in the mid eighties.
The unidentified marks could be hi-band and lo-band separators.
Chris Muriel, Manchester
JayCee
The top dial is a VHF "Turret" type switched tuner with markings of 1-13...the text to the left of the dial is "VHF"
The bottom dial is a UHF tuner with markings of 21-69 around the dial and the text to the left is "UHF"
gubar
Thanks for the replies.
Chris, thanks for the additional info - I'll try and find out what they look like.
Jaycee, thanks - but I knew what most of the text was... but around the top dial, there is a symbol, at the "6 o'clock" position, that comes between the numbers 5 and 6 (you can make out the numbers fairly easily). And, at the top, it could just be numerically numbered on another look - but there's definitely something else between 5 and 6.
Gubar
gubar
No, it isn't. I can see the shadow, but if you count around, you'll notice that 5 and 6 are not adjacent. There is another symbol in between. It's quite apparent (though not apparent enough unfortunately!).
cheers,
gubar
Chris Muriel
If true, than I still subscribe to my hi/lo band separator mark.
This thread brings back memories of turret tuners, biscuits, cleaning them and modifying them etc. during my DX TV days.
(like picking up Rhodesian TV in Band 1 from both UK and Cyprus).
I still have a Sony (black and white) VHF/UHF pprtable TV that caters for the French 819 line system (as well as UK and continental 625 standards).
gubar
Hi Chris,
is there a standard seperator mark? Or can it just be a line or anything?
Thanks,
gubar
Chris Muriel
If my theory is correct, they could have used any separator they wanted to; there is no standard.
It's probably just a line though.
gubar
Hi Chris,
thanks for that. Here's a picture of my modeled TV (line not included yet).
thanks again,
gubar
