Question for Denon DHT-500SD owners
Discussion in 'Home Cinema Buying & Building' started by reddux, Jun 15, 2005.
  1. reddux
    reddux
    Mar 6, 2005
    Did everyone get the screws/bolts for attaching the speakers to stands (the ones that screw into the centre hole on the bottom of the speakers) ???
    I'm stuck as I've got some stands but didn't get any screws/bolts with my 500SD, I was already angry that a Scart lead wasn't included in this £400+ package but will be even more mad if these screws/bolts aren't either :mad:
    BTW I've been to Wickes etc and can't find anything that fits :(
    Any suggestions :confused:
  2. Alpha Whisky
    Alpha Whisky
    I haven't made brackets yet but the manual says the screws required are M5 which is a pretty standard thread. And no they aren't supplied with the speakers. The speakers have two holes each, one in front and one behind the centre.
    The manual http://www.denon.co.uk/site/datadir/pdf/ba/Bed_DHT-500SD.pdf states quite clearly what the unit comes with, I knew what to expect and I bought a component cable for the telly and a toslink cable for the sky+ in advance.
  3. reddux
    reddux
    Mar 6, 2005
    Thanks, Can't believe I missed that paragraph in the manual :blush:
    Can finish off the install now :)
