Question for anyone with a Denon3805
Discussion in 'AV Receivers & Amplifiers' started by Ash007, Mar 14, 2005.
Tags:
  1. Ash007
    Ash007
    Dec 29, 2001
    217
    16
    Rochdale
    Does the Denon 3805 display the volume on your tv screen (even through the Component out)?
    At present I've got a 3802, which doesn't do this.
    Also, I've got a cd harddisk player plugged into my Amp. It has an S-video conection to a tv so u can chose your tracks using your tv as an onscreen display.
    The problem is that on Receivers they don't have a video-in for CD (as Cd players don't usually have a video-out). So instead I connect my harddisk players audio and video to a different input (eg VDP or VCR).
    As my cd sound is going in (optical lead) to the Amps VCR or VDP input instead of the CD input, am I losing some sound quality, Or should cd player sound be output identically regardless of whether it is connected to the CD inputs or the VDP or VCR input.
    Cheers,
    Chris
  2. Astaroth
    Astaroth
    Jun 22, 2004
    2,240
    48
    London
    +95
    All inputs should be at line level (except for a phono) and (inc all digital inputs) will be identical
    I have the denon avr2805 and it will show the details on the TV screen but only in non-progressive scan modes.
  3. wishy
    wishy
    Jan 23, 2005
    104
    19
    Boldon, Newcastle, England
    Astaroth, how do you connect your amp to your TV Av input?
    I'm having problems getting setup screen for my 2105 to work via s-video.
    Is s-video connections two way?
    As you can guess I'm a total novice at all this!!
  4. adrianl
    adrianl
    Have you checked that the s-video connection from TV to 2105 is actually connected to a 'monitor' output rather than one of the inputs?
    In Pure Direct mode on 2805 there's no on-screen display. Is this the problem?
  5. FaxFan2002
    FaxFan2002
    Jan 25, 2003
    2,098
    63
    Andover
    +109
    S-video monitor out will only display s-video inputs, not composite (yellow rca leads) or, obiviously, component.
  6. Astaroth
    Astaroth
    Jun 22, 2004
    2,240
    48
    London
    +95
    Wishy - I connect everything up with component
    Adrianl - everything (including the AVR's lcd screen) turns off during pure direct mode (excluding the stereo amp circutes obviously) to ensure there is no intereferance in playback. I know the LCD turns back on temporarily when changing volume but I dont have the TV on when listening in pure direct so cannot comment on if it also displays on the screen or not
