Question for anyone with a Denon3805
Discussion in 'AV Receivers & Amplifiers' started by Ash007, Sep 12, 2004.
Tags:
  1. Ash007
    Ash007
    Dec 29, 2001
    217
    16
    Rochdale
    Can the Denon 3805 display the volume of the Amp on your tv screen ie if I am passing the DVD picture through the amp, if I am watching a DVD and adjust the amp volume will the vol be displayed as well as the DVD picture on the screen.
    I have a Denon 3802 and it does not display the volume, and I wish it did.
  2. mugsy
    mugsy
    Nov 1, 2002
    687
    Kent
    +20
    It can indeed - yes. I think the only problem will be if you are using the component video switching in the amp and are sending a progressive signal from the DVD player - I believe there is no OSD with a progressive signal.
  3. Ash007
    Ash007
    Dec 29, 2001
    217
    16
    Rochdale
    if i have both my Sky+ (which I belive is interlaced) and a DVD (progresive signal) both going into the Denon3805 would this cause a problem, or would the amp just output to the monitor component out, whatever signal is input(interlaced or progresive). If so, then won't the TV will be recieving interlaced when the amp is on TV/DBS and progresive when switched to DVD. Is this then not a problem for the TV?
  4. HappyLad
    HappyLad
    Sky+ = interlaced SVid
    DVD = progressive component
    Assuming that your display is connected to the Denon using component cables.
    When Sky+ is selected on the Denon you will have interlaced component output.
    When DVD is selected on the Denon you will have progressive component output.
    The denon won't deinterlace the signal and upconvert so that you have a progressive component signal when watching Sky+.
    How your display device handles progressive/interlaced signals may be a problem.
    I run the component output from the Denon to a projector and have no problems swapping between interlaced and progressive component signals (apart from the OSD not being available on progressive source material as detailed above).
    I guess you might just have to try it and see if the display will recognise the 2 signals without you having to change any settings.
