Question for 32" TAU owners
Discussion in 'General TV Discussions Forum' started by Zacabeb, Jan 22, 2002.
  1. Zacabeb
    Zacabeb
    Jan 17, 2002
    474
    +9
    I have a Quintrix F inside my TV (a Philips) and it has problems with color purity. The picture is yellowish in the bottom right half and the corners are a bit dark.
    It seem to vary depending with the temperature of the shadow mask. If I watch 4:3 material for a while, when I switch to 16:9, I get the impression it's worse. If I watch 16:9 material for a while, the color purity seems to get better, but not good. Before getting this set I had another Philips, which had a Philips Cybertube and had no problems whatsoever with color purity, so I don't think it's a problem with external magnetic fields.
    It might be related to the higher dot pitch of the Quintrix F over the Cybertube (0.66mm vs. 0.7mm) making the shadow mask softer. I'm not sure if it's supposed to be like this though, does anyone with a TAU recognize this problem?
  2. Colger
    Colger
    Saw the problem on a 32PF10 and again on a 32PK20 - have no problems with my 32PG50
  3. rogerw
    rogerw
    I have a PK3, had it two weeks now, perfect picture, never knew they put these tubes in Philips sets.
