UMAR 3:16
- Joined
- Feb 9, 2005
- Messages
- 10,308
- Reaction score
- 3,036
- Points
- 2,296
I’ve run Audyssey calibration using the app. Disabled midrange compensation and adjusted the frequency selector to 400hz.
My issue is that I still prefer the flat setting rather than the reference setting. I know midrange compensation when disabled affects both the reference and flat settings, but I cant find an answer anywhere, if you adjust the frequency response does that change Happen in the flat settings. Audioholics suggest the flat setting and frequency to 100-300hz but reading elsewhere, only the reference mode takes into account any frequency settings which contradicts audiohlics advice.
So question, does changing the frequency setting affect the flat mode?
