Question about Xbox dashboard
Discussion in 'Xbox Forums' started by holtehero, Jan 21, 2005.
  1. holtehero
    holtehero
    Sep 10, 2002
    2,815
    Cambridge
    +1,734
    Don't know if anyone can help me with this, as it seems like a simple thing
    Was playing around pressing buttons on the live dashboard and suddenly the area of the screen with the options started to move, as does the whole dashboard menu area now
    it was static before i am sure, i have looked at manual and website, no joy
    and no i hadn't been drinking
  2. captaineyecatch
    captaineyecatch
    Feb 9, 2002
    2,013
    38
    South of Heaven
    +21
    Done this last year its much better now isnt it.
    Its the same thing you do to get the light show full screen when playing music just press+hold Y and then press X(while still holding Y) i think thats right although it may be X then Y??
  3. holtehero
    holtehero
    Sep 10, 2002
    2,815
    Cambridge
    +1,734
    Still online captain :)
    Thanks i will go and try it as i pressed a button and it started moving, made me feeling a bit queasy!!
    Where is all this info kept as i haven't seen it elsewhere, also looking for the network troubleshooter that is listed on live, but i couldn't find the bit where it tells you about ICMP and what policy your router is, the menu doesn't seem to appear!!
  4. captaineyecatch
    captaineyecatch
    Feb 9, 2002
    2,013
    38
    South of Heaven
    +21
    it only appears when you disconnect from live eg pull the plug then a menu pops up put the plug back in and connect.... you get all the DNS connecting bits and then when it says connected to live you press the Y button to get another screen( or 2 screens?) with all your MTU, NAT etc settings.
