Question about the Pioneer Pioneer VSXD2011S
Discussion in 'AV Receivers & Amplifiers' started by antz, Aug 14, 2003.
Tags:
  1. antz
    antz
    Aug 13, 2003
    335
    Brum
    +8
    Will the Pioneer 2011 be able to drive my KEF reference Speakers, the impedance ranges from 4 ohms (for the L/R) to 6 ohms for the other speakers.
    I'm looking to upgrade, and am trying to keep below £1000.
    Antz
  2. voodoo
    voodoo
    Nowhere near as good as a dedicated high quality power amp but you can bi-amp the fronts with this model [if using a 5.1 and not 7.1 set up].
  3. Daneel
    Daneel
    Dec 5, 2002
    2,843
    68
    London
    +8
    I would suggest it will struggle with 4 Ohms, I haven't tried it for myself though. Maybe try a second hand higher end Denon or if you are lucky a Rotel 1075/1066 combo to keep it under £1000?
