Question about speakers ? *newbie*
Discussion in 'Home Cinema Speakers' started by llanellijack, Mar 28, 2005.
  1. llanellijack
    llanellijack
    Mar 21, 2005
    291
    Llanelli
    +3
    Hi, I have a Sony Davs-888 home cinema surround system but now I want to upgrade to a HDMI DVD player to go with my Pioneer 434HDE plasma. My question is, can i use my current speakers and subwoofer with a separate AV receiver and DVD player or will they only be compatible with the DAVS system ?? Also, if I go down the separates route, do I need an AV reciever and an amp or just a receiver ?? What's the difference ?? Sorry if these questions are basic but I'm very new at this. Thanks in advance for any help.
  2. chedmaster
    chedmaster
    Jan 29, 2005
    2,661
    68
    +28
    an av reciever includes a tuner and everything an av amp has (ie decoder, and all the surround amplified outputs etc), you buy either one or the other, depending upon whether you want a tuner or not. Most are recievers, especially on a budget level as far as i know.
    On the dvd question i think it will still have optical and/or coaxial digital out, in which case, as long as your sony has these inputs, you will be ok, but the quality of seperates with decent speakers is always much better.
