I have a query about speaker sensitivity and I hope someone can clarify my understanding. I currently have a Sonos Connect Amp that I use for music and also to for my TV. The TV is connected to it using a stereo analog output and this works fine and allows me to stream the TV audio to other rooms in the house. The downside to this is that there appears to be a ground loop between the TV and the Sonos (even though they are fed from the same mains point) and so I get a hum when I turn the TV off. I have added a Behringer Hum Destroyer to the signal path and while this has helped it hasn't eliminated the problem entirely - there is still a very slight hum with the TV off which I can
live with. I am now looking to upgrade my speakers to a pair of Q acoustics 3050 floorstanders and as these have a relatively high sensitivity of 92dB I am concerned the hum will be more noticeable. My understanding of speaker sensitivity is that for a given signal level the perceived volume level will be higher (for a higher sensitivity speaker) but if the overall volume levels will be higher I will just turn down the volume level on the Sonos to normalise them to their current level. If this is the case then I will be no better or worse of then I am currently - can anyone confirm this will likely be the case ?
Also if anyone has any suggestions for removing the hum altogether then I'd love to hear them.
Thanks,
Declan.
Thanks,
Declan.
