Question about RW
Discussion in 'Blu-ray & DVD Players & Recorders' started by Hazzie, Dec 2, 2004.
  1. Hazzie
    Hazzie
    Nov 18, 2004
    4
    Can someone explain the DVD RW to me please. I was under the impression that
    DVD R was write once
    If you rceorded a 30 min program then thats the disc finished with
    DVD RW was re-writeable
    If you recorded a 30 min program then you could come back at a later date and record again up till the disc's storage limit and then its finished with.
    However, i was told by a shop assistant, that didnt look confident in what they were saying, that you could write over a whole disc time and time again, very much like a VCR Tape.
    Is that true, and if so is it any special format or just a plain dvd recordable machine?
    Thanks,
    Hazzie.
  2. johnjackthom
    johnjackthom
    Sep 20, 2001
    748
    Northumberland
    +283
    Hi Hazzie,
    With DVD-R you can record your 30 min programme and providing you don't finalise the disc, more can be added later until it is full.
    Unfortunately your DVD-R wont play on a standard DVD player until it has been finalised.
    DVD-RW can be used in a similar way to video tapes. You can erase and re-use them a limited number of times. Probably something less than the 100 times I've seen quoted.
    Some recorders support DVD-RAM which operates rather like DVD-RW but can be re-used many more times.
  3. Hazzie
    Hazzie
    Nov 18, 2004
    4
    Thanks for the information. :thumbsup:
  4. liteswap
    liteswap
    Jun 21, 2004
    336
    East Sussex, UK
    Note that with a non-finalised DVD-R, you can erase stuff which makes it look as if it's disappeared but you never get the space back, as the medium itself is write-once only. All erasing does is wipe out the entry in the disc's index that points to the recording.
  5. OT31
    OT31
    Does this mean you can cut adverts out of a DVD-R (if you have the right recorder)? I didn't think you could.
  6. eddyad
    eddyad
    Jan 5, 2003
    940
    Hampshire
    +9
    I don't think you can do A-B 'erasing' on a DVD - only a complete item. As the medium is not re-writable, I assume that complete new index data is written after each change, and the latest version used when the disk is played. After finalisation the medium becomes portable.
  7. liteswap
    liteswap
    Jun 21, 2004
    336
    East Sussex, UK
    Correct, as I understand it.
