Question Question about rear surround speaker placement
Waynester
Hi guys
currently using 2 x Q Acoustic 3010’s on their proper ST stands as rear surrounds in my setup...
just managed to sell them within 90 minutes of putting them on Facebook, pleased with my £135 sale!
I’m trying to decide on a pair of Monitor Audio Bronze 2’s on stands OR the Bronze FX?
my problem is that my sofa is right against the rear wall, so I can only have whatever speakers I choose to face inward towards my ears like this, can I use either speakers like this? Which speakers would be better would you think?
I can’t put them on the wall as my flat is rented
kenshingintoki
Is this a 5.1 setup or 7.1?
If its 5.1, that speaker position is perfect as per dolby standards so I don't see the problem.
Waynester
Wayne, how you like the new big ass Bronzes? Can you post photo of your front stage? :)
I’ve been waiting 4 weeks for the things to arrive lol!
Delays from Monitor Audio unfortunately
My living room is this empty so I’ve used a Yamaha YAS-103 soundbar to see me through 🤣
The 500’s are being delivered Friday this week... will post up once all set up and calibrated
Waynester
Maybe some MA Apex A10s on stands?
BX2 are going to be annoying at that distance.
id love the Apex A10’s but can’t afford them
would a pair of lesser Bronze 1’s be better than my Q Acoustics 3010’s?
Waynester
Gasp3621
The Dynami Uno stand would work too. You can get the 750mm and 900mm height which would put the speakers bit higher which could be prefered especially if you are sticking with 5.1 system!
Waynester
Yeah my bad mate! Just cancelled the DUO 60cm high stands as they are 5cm lower than my QA stands, just realised when I recline my chair to watch movies, they will be way way too low! Better to be higher?
I’ve re-ordered the UNO ones at 75cm in height, means with the Bronze 1 speakers on top that’ll be 101cm... current QA 3010 on stands are 88cm.. might be better for me
Gasp3621
Yeah man higher the better esp. as they are so close to you. Although the 900mm stand could look bit goofy, so maybe the 750mm is best compromise.
Waynester
Oh crap! 🤦‍♂️
Just realised the top plate on these UNO stands are a lot smaller than the speakers, have a look at the measurements, the DUO would be better but not tall enough... does it matter that speakers are bigger than the top plate on these new stands matey?? Don’t want em falling off 😳
Gasp3621
Oh crap! 🤦‍♂️
Yep i noticed, but i wouldn`t worry too much as you can use blutack or something similar to stick them on stands. I had smaller top plate with my Bronze 1s too. You have them quite close though so they are more in danger if you party often with buddies, that goes for any stands. :laugh:
Waynester
My years of partying are well and truly over fella 🤣
I’m 47 in November and I like being single and free 😆
I’ll try not to knock em off after I’ve had a few ales🤣🤣
looking at the measurements though, the difference isn’t huge and shouldn’t hang over by much... 👍🏻
Do I have to fill these stands with sand? Or not bother?
Gasp3621
Haha! I haven`t filled stands to this day, but you could make them heavier that way. Other than that you might have to ask from some golden ear how much better they sound afterwards. 🤓 If the stands are wobbly then maybe consider the filler sand something cheap which is often used.. The white ash finish is quite nice, hope you like it. I had the same with white stands to blend better with white walls. The finish is slightly different with the new models, but that shouldn`t matter as they aren´t side by side.
Waynester
I’ve ordered the white gloss shiny finish, not the matte... I’m sure I’ll like them 😊
