Question about rear projection TVs
Discussion in 'General TV Discussions Forum' started by blue_harvester, Dec 15, 2004.
  1. blue_harvester
    blue_harvester
    Jul 28, 2003
    108
    16
    Belfast, Northern Ireland
    I know that if you leave static images on a rear projection tv for extended lengths of time this can cause the image to be permanently "burnt" into the screen. What I want to know is, if you watch alot of widescreen movies in letterbox format, will there be two bars burnt into the top and bottom of the screen?
  2. Tight Git
    Tight Git
    Mar 3, 2004
    6,332
    +597
    Yes, it's exactly the same issue as with on screen logos etc.
    But, as with on screen logos, you'll have to watch an awful lot of widescreen films at high contrast to see the effect.
    (If you stick to widescreen films, it won't matter anyway!)
  3. alexs2
    alexs2
    Nov 13, 2002
    13,957
    +1,671
    Had ours for a couple of years now,and no problems with screen burn of any type.
  4. blue_harvester
    blue_harvester
    Jul 28, 2003
    108
    16
    Thanks for the reply guys. Yeah I suppose if I stick to widescreen movies it won't matter. By the way, how long do Rear Projection TVs generally last? I mean is there a certain life span for the internal bulbs like normal projectors?
  5. Tight Git
    Tight Git
    Mar 3, 2004
    6,332
    +597
    What type of RP are we talking about?
    When I made my original comments(above) I assumed CRT, but now you mention bulbs.
  6. alexs2
    alexs2
    Nov 13, 2002
    13,957
    +1,671
    DLP and LCD RPTV's will of course not be susceptible to screen burn,whereas a CRT based one has tube life,and screen burn to contend with,as possible hazards,and many folks translate CRT life into bulbs when discussing CRT based RPTV's as well.
  7. Tight Git
    Tight Git
    Mar 3, 2004
    6,332
    +597
    Assuming that's correct in this case:
    Blue Harvester,
    CRT's in a projection system (front or rear) are run very hard and are generally reckoned to have a useful life of about 10,000 hours.
    That translates to one film a night for about 10 years.
    Not too bad, although you do say you watch a lot of movies! :laugh:
    The real problem is if one tube fails after, say, 5,000 hours.
    You may well have to replace all three (at £400 each) in order to get a good colour balance.
    Hope this hasn't spoiled your Christmas!
  8. alexs2
    alexs2
    Nov 13, 2002
    13,957
    +1,671
    Thats absolutely right,but I think it's a factor you have to take into account when buying a projection system of whatever type in that bulbs or tubes can be very expensive to replace,and certainly bulbs for DLP or LCD systems can be pretty short-lived as well as quite costly.
  9. GagHalfrunt
    GagHalfrunt
    Sep 1, 2001
    527
    North Cotswolds
    +3
    What this comes down to though is setup.
    If you use Avia or whatever to set the picture up when you first get it I don't see this being a problem. It's only because people leave the contrast set too high. Also never leave the EPG or whatever on the screen all the time.
  10. condyk
    condyk
    Jul 12, 2003
    438
    Jewellery Quarter, Birmingham
    +7
    What is Avia? I have a new RPTV arriving tomnorrow and want to set it up so it has a great picture and lasts as long as possible without screen burn or failed bulbs (well, 2-3 years anyway!)
  11. condyk
    condyk
    Jul 12, 2003
    438
    +7
    Don't worry, I searched around and found out what it was. Just what I need I reckon and so a copy ordered. Delivery 10 days or so. Will give time for TV to settle down.
  12. blue_harvester
    blue_harvester
    Jul 28, 2003
    108
    16
    Well is there any best practice when using Rear Projection systems like leaving the TV on standby etc. to prolong the life of the set?
  13. runningback
    runningback
    Feb 4, 2004
    339
    generally speaking lower settings=longer tv life, especially contrast and brightness.
  14. alexs2
    alexs2
    Nov 13, 2002
    13,957
    +1,671
    very true,especially considering the default values that most of the manufacturers seem to have the TV's set to for delivery...mine was at 100% for brightness,sharpness and contrast,and is now at around 50% for all of those values,so well worth spending some time adjusting the picture until it's watchable in an ordinary house.
  15. Tight Git
    Tight Git
    Mar 3, 2004
    6,332
    +597
    Some manufacturers set the defaults high so that the set will stand out from others if the shop puts it on display.
    Not good practice technically, but you can't really blame them.
    That's why the more knowledgeable viewer (= Forum member :D ) immediately adjusts all the settings to a more reasonable level.
  16. alexs2
    alexs2
    Nov 13, 2002
    13,957
    +1,671
    Exactly my point...saves the retailer doing anything to it when putting one on display,but leads to severe eye-ache within minutes in an ordinary room....and also earache from one's wife who sees new 50"RPTV and immediately declares it to be unwatchable.... :rotfl:
  17. GagHalfrunt
    GagHalfrunt
    Sep 1, 2001
    527
    North Cotswolds
    +3
    Not only that, but the picture will look far more natural when you've "fixed" it. Mine did.
