Question about Panasonic TY42TM6DB DVI-D Terminal Board
Discussion in 'Panasonic TVs Forum' started by macguffin, Sep 21, 2007.
  1. macguffin
    macguffin
    Mar 11, 2005
    498
    +8
    I have a panasonic PH9 plasma and was wondering could the Panasonic TY42TM6DB DVI-D Terminal Board accept a 48hz siginal from a HTPC running powerstrip? Would this reduce/eliminate 3:2 pulldown judder? I know the HDMi boards are locked at 50/60hz. Would I expierence any HDCP problems. I would be using a HDCP compliant graphics card. Would there be a difference in quality between hdmi and dvi?
    thx
    macguffin
  2. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Sadly this does not work on the TM6, it's 50 and 59.94 only, and no native res at 50Hz. No HDCP issues, but the board and screen are both limited, there is no way round this.
