Question About Panasonic Pwd7
Discussion in 'Plasma TVs' started by gunizzle, Aug 30, 2005.
  1. gunizzle
    gunizzle
    a question!!
    Can you select any other input when your doing multi PIP, at the moment i have nothing on input 1 and input 2, my sky comes through on input 3 but i cant seem to do PC picture in picture with input 3 only input 1, any ideas???? ive looked everywhere in the settings but nothing.
  2. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    No idea why not, mine will. 1st, select input 3, then select PC, then PinP, and there it is. It does the PinP bit with the last input selected, by default, I think.
