Waynester
Hi Guys
a newbie into setting up my system choice, haven't bought it all yet!
My bedroom is 10 feet by 20 feet
I've Just bought a Panasonic TX-55CX802B Television, it's going up on my wall on Monday
I've decided to get the following equipment to add to it for 5.1 Surround Sound and i also want to listen to CD's using my Marantz Signature CD Player, but bit worried about what CD's will sound like..
Denon AVRX2200W Home Cinema Receiver
Cambridge Audio Aero 6 Speakers
Cambridge Audio SX70 Centre Speaker
Cambridge Audio SX50 Speakers
Cambridge Audio SX120 Subwoofer
If I connect all this up and buy a separate hi fi power amp, how do I use this power amp on its own with just the Aero 6 Speakers if there already connected to the Denon AV amp as front surround sound speakers?
or do you think the Denon AV Amp will suffice and be good enough for listening to Music CD's
Or can anyone suggest a better system and setup procedure?
Does my system choice look okay?
Will be watching lots of Blu Ray music concerts and movies etc
My budget is £1250 for everything
