question about hdready tv
Discussion in 'Televisions' started by savvas, Sep 5, 2005.
  1. savvas
    savvas
    hi at first forgive me if my english are bad :) my lcd tv have an hdmi input but its not hdready. i connect it with a dvd player with hdmi output but it only shows at low resolutions with some snow and in higher resolutions the screen is black . i think is because my tv doesn't have a neccesary decoder. please help me about this
  2. Rimmer
    Rimmer
    What LCD do you have?
  3. savvas
    savvas
    my tv is a toshiba 37WL56P and the dvd player is a samsung DVD-HD850
  4. savvas
    savvas
    hey guys does anyone have an answer or my qusetion is just too stubid?
  5. AML
    AML
    Jul 22, 2004
    4,988
    Tokyo
    +229
    Your question is not stupid! And your English is good! :)
    Im not familiar with either the TV or the DVD player you have, but ill try to answer your questions.
    You said that your TV has an HDMI imput? If it does it should be HDCP.
    The DVD player also has the same HDMI unput?
    I think the problem might be with the settings you are using. Either the DVD player or the TV.
    It could be the frequency (50hz or 60hz). You need to make sure the DVD player and TV are using the same frequency.
    Also need to check that both the DVD player and TV support HDCP conections. You should be able to use that TV at 720p or 1080i as it does support it.
    Try different settings untill you make it work. If nothing works then try contacting the shop where you bought everything.
    Good luck!
