Question about Harmony Touch Remote
Fat_Tony
HI folks
Ive just been through the gruelling ordeal of using MyHarmony to set up a remote. Its great when it works but I find it so hit and miss, it wouldn't even recognise the remote plugged in for over half hour, despite it appearing on the remote screen that it was connected.
Anyway, my question is - when you use the Off button on the remote and it shuts everything down, is it possible to exclude a device from this? We have a sky box that is split between my home cinema and the bedroom, whenever I shut down in the cinema it turns off the box so if possible I would like to exclude the sky box from the all off command.
logiciel
Specify that its Off command is "none".
