Question about euro plugs
Discussion in 'AV Receivers & Amplifiers' started by Kaleb500, Nov 3, 2004.
  1. Kaleb500
    Kaleb500
    Apr 4, 2004
    57
    My mates got himself a 3802, but with a euro plug. Just wondering when you put it in a converter does it matter which pin goes in the positive and which in the negative? I assume not, since the plug itself seems to be a uniform shape, meaning that in europe they would be able to plug it in either way.
  2. Peridot
    Peridot
    Aug 24, 2004
    2,989
    Newport, South Wales
    +293
    Well, Russ Andrews sells a gadget to check mains polarity because, it is claimed, your equipment doesn't sound as good if live and neutral are reversed :laugh:
    Utter b :censored: s !
    However, would it not be better to cut off the euro plug and connect a UK 3-pin one? Or buy a new lead. The quality of adaptors is often poor and could affect equipment performance.
    Regards,
    Dermot
