question about dvd-ram
the_stalker
I know that you can buy 4.7gb (120min) but there also 9.4gb (240min) I know this might be supid question or thick but is the 9.4gb like -/+ DL except smaller size?
cheers
knotpc
The Panasonic ones I have are the same, just the larger capacity are double sided. So not so good for continuous recording as you have to turn it over.
Mind you all of mine are in Disk type cartridges.
Regards
knotpc
the_stalker
knotpc said:
The Panasonic ones I have are the same, just the larger capacity are double sided. So not so good for continuous recording as you have to turn it other.
Regards
knotpc
thanks - I might as well get 120min one.
