Question About Denon AVC-A1SRA
Discussion in 'AV Receivers & Amplifiers' started by TheGoose, Mar 15, 2005.
Tags:
  1. TheGoose
    TheGoose
    Hello I have a question about my Denon A/V Amplifier, its quite a simple question but cannot find any info so far about it.
    Inside the amp are two 80mm cooling fans facing toward the torriddol transformer, to my knowledge they havent turned on yet and I would like to know whether they are activated simply by the temperature of the unit OR by the volume setting as you crank it up!
    Thank You
    Michael
  2. Jase
    Jase
    Mar 16, 2001
    10,956
    United Kingdom
    +3,417
    They are temperature activated as far as I know. I've never heard mine in the three years I've had my Denon, even when it gets quite hot. :)
