Question about DD 5.1 for the Xbox 360 on LCD screen.
Discussion in 'Home Cinema Speakers' started by Morris Schæffer, Aug 20, 2005.
  1. Morris Schæffer
    Morris Schæffer
    My current Xbox is hooked up to Logitech Z-680 5.1 speakers via optical. As you know, the optical cable plugs directly into the SCART unit of the Xbox.
    For the Xbox 360, I was thinking of upgrading my speakers to Logitech's new Z5500 range as my experiences with the Z-680 are quite positive. I've also come to understand that component cables will produce the best possible PQ on an LCD screen such as the V-Series from Sony. My question is, where will the optical cable go if one end is obviously plugged into the decoder of the speakers themselves?
    Thanks a bunch. :)
  2. bilbo2e
    bilbo2e
    Jul 27, 2005
    17
    Get hold of the official HD kit from liksang , it has an optical out on it just like the official scart - great quality too (+ component cables :D ).
    Might also want to read this elsewhere as far as getting HD picture from your XBox without having to hardmod it.
    Ok Matey? :thumbsup:
  3. Morris Schæffer
    Morris Schæffer
    Thanks Bilbo.
    EDIT: I don't seem to be able to find this kit on lik-sang.
  4. bilbo2e
    bilbo2e
    Jul 27, 2005
    17
    No worries dude try here .
    Glad I could help.
  5. Morris Schæffer
    Morris Schæffer
    Hm. It says:
    "High definition AV pack for all Xbox consoles (Except PAL)."
    Sadly, I live in pal territory.:(
    EDIT: I wonder why it won't work with pal consoles though. It's just a cable. :confused:
    EDIT 2: Pal units are available also so I'm gonna be all right. Thanks Bilbo. :clap:
  6. bilbo2e
    bilbo2e
    Jul 27, 2005
    17
    The cable will work regardless - what they mean is that the Hi Def capabilities are technically not available on an out of the box PAL machine (all you would get is a slightly better than RGB picture). Thats why you have to do the mod.
  7. Morris Schæffer
    Morris Schæffer
    But with the 360 being backwards compatible, I might as well use my Xbox 360 all the way. In essence, the old Xbox becomes utterly obsolete in every conceivable way, except for our living room where a DVD player is still lacking.
  8. bilbo2e
    bilbo2e
    Jul 27, 2005
    17
    Obsolete unless you actually want to play any original Xbox games - the backwards compatibility has not been confirmed - nor has what form it will take :lesson:
