Question about ceiling mounting projector
Discussion in 'Projectors, Screens & Video Processors' started by jianbing, Jan 14, 2005.
  1. jianbing
    jianbing
    I'm thinking of buying a Panasonic-AE700U and ceiling mount it in my 8' height ceiling bonus room. However, AE700U has only 64% vertical lens shift. After a rough calculation, I found it might not be feasible to project to a 100" screen at the center of the wall with a ceiling mount. Have anyone do ceiling mount with AE700U? Would you please share your experience?
    Thanks!
  2. Oakleyspatz
    Oakleyspatz
    Oct 9, 2004
    3,576
    Woking
    +231
    Dont forget the pj will be upside down so it would be like placing it right way up on the floor ( well, a few inches off the floor) and projecting onto a clear wall. You should have no problems with the ceiling mount so long as the projector is far enough away from the screen
