Question about Cables
Discussion in 'Xbox Forums' started by Illuminattile, Jan 16, 2008.
  1. Illuminattile
    Illuminattile
    Dec 1, 2007
    23
    I'm finally upgrading to an HD TV, and I'm not sure whether I need to buy a HDMI cable for my Xbox 360 (Premium, bought earlier this year).
    [​IMG]
    This is the cable I have, which I understand is a HD component cable (based on the FAQ). Will that give me HD quality gaming, or do I need one of these?
    [​IMG]
  2. shil
    shil
    Apr 13, 2006
    1,587
    116
    +831
    The component cable will give you HD gaming. Most HD TV's now come with component input so this should be fine for you. However, if you bought a premium with HDMI output you can use the HDMI cable. You can also use a 15pin VGA lead if you wanted thats only if your TV supports a VGA input. :)
  3. Illuminattile
    Illuminattile
    Dec 1, 2007
    23
    Thanks shil. I don't think my Premium does have a HDMI output, so it's obviously not new enough :p
    Is there much benefit to using the HDMI cable? Bearing in mind that my TV isn't full HD, so I won't be getting 1080p anyway?
  4. shil
    shil
    Apr 13, 2006
    1,587
    116
    +831
    From the recent posts in the 360 section there doesnt seem to be any major quality differences. So your good to go with Component. :)
    Check this thread out below...
    http://www.avforums.com/forums/showthread.php?t=690170
