Question about Cables
Discussion in 'Projectors, Screens & Video Processors' started by Frankeh, Sep 10, 2005.
  1. Frankeh
    Frankeh
    Ok I'll be receiving my Sanyo Z3 next week.. though I still have to buy decent cables, I'll be playing on my Gamecube, PS2 and Xbox on the PJ.. so I need cables for those systems
    Component Cables are the best right? I'll be buying component cables for those systems off lik-sang, here you can find all the component cables they have:
    http://www.lik-sang.com/search.php?...ent&Button=Zoek
    the thing is.. I can't directly connect that cable from my Gamecube/PS2/Xbox to the projector, because my projector is hanging on the other side of the room, the distance will be about 10 metres (= 33 feet) so I need a second pair of cables right?
    So I need a second pair (3x) of component cables like these? : http://www.accellcables.com/press/p...nt_Cable_St.jpg
    Male on both sides.
    Is all of this correct? Which component cables on lik-sang do you recommend me? Third pary is equal to first party? Which regular component cable do you recommend me? (gold ones, ...)
  2. Scotty Boy
    Scotty Boy
    Nov 11, 2003
    1,106
    38
    +6
    To make use of Progressive scan, you'll need your xbox modded and your GC to be a US one. Just so you know. :)
  3. Frankeh
    Frankeh
    I know
  4. dmjohnson123
    dmjohnson123
    Nov 25, 2002
    265
    Wetherby near Leeds
    +5
    I'd have thought you'd need a female to male component cable because if I have understood correctly your in effect extending the GC/XBox cables.
    I'd check this but my feeling is female to male.
    Anyone else know ?
  5. Frankeh
    Frankeh
    yeh I extend the GC/xbox cables.. so the Xbox component cable is like this: on the one side you have the connector for the console itself (Xbox) and on the other end you have the male component.. I need to connect this with a new component cable, on that side a female component and on the other side to the Projector a male component
    yes I think you are right
  6. dmjohnson123
    dmjohnson123
    Nov 25, 2002
    265
    Wetherby near Leeds
    +5
    That's how I'd worked it in my head Frankeh but I wasn't sure exactly what was on the end of the xbox cable. If its definately male then yes you need a female to male component cable to extend to your pj.
  7. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,762
    The Borders
    +3,088
    Frankeh
    'Component is Best' - definitely worth doing everything on YUV 'Component' if you have that option on all of your source devices.
    Multiple Sources - if you have an AV Receiver does it have YUV switching; if not have you considered adding in an external 'Component' Switcher?
    Cables - BetterCables, VanDamme and Mark Grant are all well made cables using high quality components at a range of affordable price points; your 10m run needs to be decent quality or you can suffer signal loss which negates the extra cost of going YUV 'Component' in the first place.
    Gold Phono's are NOT an indicator that your looking at a decent cable! Lots of cheap tat comes with Gold Plating - see http://news.bbc.co.uk/1/hi/business/2010949.stm :)
    Best regards
    Joe
  8. MikeK
    MikeK
    Oct 9, 2004
    2,231
    83
    +316
    Lots of expensive tat does as well !!!!!!!!
  9. Frankeh
    Frankeh
    Thanks for your time, someone said to make my own component cables, do you recommend that?
    he said:
    Buy some coax, then some RCA connectors
  10. Anim
    Anim
    Feb 2, 2002
    1,682
    Cheshire
    +62
  11. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,762
    The Borders
    +3,088
    Hello Frankeh
    Your mate forgot the Sharp knife, wire cutters, soldering iron or crimp tool, plasters and cups of tea!
    When you consider a well made set of VanDamme or Mark Grant RCA to RCA cables will cost you less than £45.00 its hard to see where the benefits of DIY are if your not someone who makes up lots of cables.
    Best regards
    Joe
    PS Anim - use the Banner adds; remember they fund this site :)
  12. Anim
    Anim
    Feb 2, 2002
    1,682
    Cheshire
    +62
    Sorry, next time I will check all banner ads before suggesting other links.
  13. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,762
    The Borders
    +3,088
    Morning Anim
    I'm just in a grumpy mood and Banner Adds are top of the hit list this AM :)
    Best regards
    Joe
  14. Frankeh
    Frankeh
    Making the cables is no problem, my father can make them easily on his work.. is the quality of own made component cables poor? (10m)
