ZeroOneTwo
Hi, I'm considering the new Yamaha network CD player. It says it uses vTuner for Internet radio. (so if whatever that you have uses vTuner please chime in) Problem is, when I go to the vTuner website and browse through the stations there, they are all in awful quality, 128kbps MP3, usually lower. I used the links provided and opened them up in iTunes. I opened BBC Radio 3 and there was a piano piece playing. I nearly went into a coma.
But I know that internet radio can sound okay. When I listen to the same stations with the application Radium (not with the vTuner links of course, with the in-application search engine) they sound much much better.
So I'm a bit confused here. Do the devices using vTuner use those same exact links with the exact same crappy quality? Or do HiFi companies like Yamaha use a vTuner service of their own with different internet radio addresses? That would make a lot of sense but I want to know if that is right. (I google'd and didn't find an answer)
So c'mon, help me.
So c'mon, help me.
