Quest for High End Figure 8 plug.
Discussion in 'Cables & Switches' started by pemberto, Jun 17, 2004.
  1. pemberto
    pemberto
    Oct 14, 2003
    500
    28
    Huntingdon
    +32
    The quest for a high end Figure 8 plug has been around for a while and a few people regularly post on these forums to check the status of this holy grail of AV cables.
    I have decided that enough is enough. I have approached a couple of electrical cable manufacturers to check the feasibility and potential costs associated with building a prototype with an aim of going into production.
    What I would like to ask the members of this forum is for feedback on the following items:
    • What specification would you look for e.g. Silver or Gold plating, accepted cable diameter​
    • What cost would you be prepared to pay e.g. Wattgate 320 @ £ 20.00 or Wattgate 350 @ £65.00​
    • Would you consider upgrading your cables if a new figure 8 plug became available​
    • How many cables would you look to upgrade​
    Once armed with this information, I can then start to workout production costs and get a better understanding of what I am looking to take on.
    Paul
  2. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    I'd go for some but wouldn't be looking to spend more than about a £5. Basically just a bigger one for larger cable with well machined contacts and solder points.
    Don't forget the cloverleaf connector for projectors.
  3. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,117
    83
    Over the Hill & Far Away
    +119
    Do wattgate do figure 8 connectors ? there usually IEC...(and I think the 350 seriously overrated..)
    I got my excellent quality figure 8 cable from Mark Grant on these forums...about £25 I think..
    Matt
  4. StevieDvd
    StevieDvd
    Dec 27, 2003
    1,368
    Stevenage, Herts
    +151
    Russ Andrews do convertors from the IEC to Fig8 if it helps anyone.
    Steve
  5. pemberto
    pemberto
    Oct 14, 2003
    500
    28
    Huntingdon
    +32
    Matt,
    Thanks for the response. No Wattgate do not make a Figure 8 plug. I was using them as an example of build quality Vs. Price
    I use both the Wattgate 320 and 350 with Van den Hul Mainsstream cable. My own view is that the 350 does perform better than the 320.
    I also have Mark Grant Fig. 8 cables which are very good, but they are terminated with a 60p figure 8 plug. I am sure that Mark would use a better quality plug if they were available.
  6. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,117
    83
    +119
    Ahh.. I see.. yeah figure 8 connectors do seem missing from the quality plug market.. surprising really as so many itesm use them.
  7. bjcol
    bjcol
    Jul 8, 2002
    24
    Bristol
    I would be interested in such a plug, I'd be prepared to pay £15 for one. Does anyone know where I an get a cheap figure 8 plug to use in the meantime?
  8. kraal
    kraal
    Aug 23, 2004
    96
    Portugal
    Audusa Eupen also use fig8 plug.
    I'm looking also for a good fig8 plug, so, no one know any manufacture? All my cables are made for me, using Mainsstream, Lorad and Lapp and waiting for a Eupen for my dvd player.
  9. mw3cdj
    mw3cdj
    Nov 12, 2002
    396
    West Wales
    Don't know if you realize that Mark Grant from this forum actually makes a fantastic fig 8 power lead . I use 2 myself ...
    Regards,
    Daran.
  10. marck
    marck
    Jul 10, 2002
    600
    London
    I bought a couple of fig 8 leads from DNM - I think they cost about £25.
  11. pemberto
    pemberto
    Oct 14, 2003
    500
    28
    Huntingdon
    +32
    Just to let people know. If did a bit of digging around and had a chat with a few vendors. To produce the setup to build a prototype would cost around 2k.
    So at the moment I am hanging back until I can find a cheaper source. I am now looking outside the UK.
    Pemberto.
  12. Mark Grant
    Mark Grant
    Oct 27, 2000
    1,357
    63
    East Yorkshire, England
    +171
    This is an old thread :)
    Any luck with finding decent quality figure 8 and maybe 'clover leaf' connectors - I need a large quantity soon if anyone knows a supplier.
    Thanks,
    Mark.
