Query regarding width of Z4
Discussion in 'Projectors, Screens & Video Processors' started by belgrade, Mar 29, 2006.
  1. belgrade
    belgrade
    Mar 4, 2004
    137
    16
    newcastle
    Could a forum member with a Z4 please help me out? :lease:
    I am waiting for my Z4(due to arrive later in the week), but I need to buy a tv wall bracket for it tomorrow.
    Most tv brackets I have seen are 30cm wide, and I know that the Z4 is 38 cm wide. However, what is the distance between (and including) the feet of the Z4,
    width wise? I am hoping that this will be less than 30cm.
    Does anyone have any other suggestions for mounting the Z4, (but not ceiling mounting?)
    I was thinking of placing it on a wall shelf, but I could not find any shelves deep enough to house it, hence teh tv bracket idea.
    Thanks, in advance :smashin:
  2. sjackson
    sjackson
    Jan 8, 2006
    2,189
    116
    Ireland
    +539
    I'm getting a wall bracket from Argos to mount mine. This one:
    http://www.argos.ie/ProductDisplayTRK019?partNumber=5340277
    If you look on the underside of the Z4, there are a few (3 I think) holes for ceiling mounting it. What I'm going to do, is drill matching holes in the bracket plate, and screw the Z4 to the plate.
    But between the plate and the Z4, I'm going to put a nut (at each screw), so that the projector itself will be about 5mm off the actual plate to allow for some air flow.
    Should work ok.
