Query re Panasonic PW5B and PW5D terminal connections.
Discussion in 'Panasonic TVs Forum' started by bossc@, Dec 2, 2003.
  1. bossc@
    bossc@
    Dec 20, 2001
    1,154
    +268
    Quick question - are the terminal board connections the same between these 2 screens. I know they both have 15 pin SubD but is the PW5B only able to be used for the tuner or can it accept a video input?
  2. StooMonster
    StooMonster
    Nov 20, 2002
    4,974
    Kent
    +314
    Is this US numbers or something?
    TH-50PHD5 or TH-50PHW5 are the models with component and AV (composite and s-video) input as well as VGA.
    TH-50PHD5B or TH-50PHD5BX (or TH-50PHW5B or TH-50PHW5BX) means British edition, also to be seen are TH-50PHD5E or TH-50PHD5X and other letters too; this part of the code signifies country. If it doesn't say B or BX at the end it probably means that it's imported from European mainland, and will have different warrenty conditions.
    Additionall, TH-50PHD5 or TH-50PHW5 with letter D or W means colour of bezel, where D is black and W is silver and A means silver with speakers.
    Finally, TH-42PHD6 vs TH-42PW6 is resolution where H means High Definition and absence of H means Standard Definition.
    Therefore code is:
    TH-[screensize]P[resolution][bezel-colour][generation][country]
    I think the P is for PAL, T is for television, H is for plasma (x for CRT or LCD).
    The Tuner option usually says Tuner in the name, e.g. TH-50PHW5-Tuner
    StooMonster
  3. StooMonster
    StooMonster
    Nov 20, 2002
    4,974
    Kent
    +314
    I'd suggest that one is of British origin and the other is German.
    StooMonster
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    tuner board relys on a card internally some came with tuner and card standard came without tuner card and RGB/YUV,Svid/composite board. all have VGA
  5. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    ...but any screen can accept tuner card or video card, so either can do both.
  6. bossc@
    bossc@
    Dec 20, 2001
    1,154
    +268
    Sorry lads - was typing in the last minute countdown to leaving work so I apologise for not being very explicit. I was referring to the 5 series Panasonic panels, should have put the full designations as 42PW5BX and the 42PWD5 but have had my rather stupidly phrased question answered.
    Thanks all.
