Query re: openin nokia ondigital boxg
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Mr.D, Jun 2, 2003.
  1. Mr.D
    Mr.D
    Jul 14, 2000
    11,167
    +1,209
    I want to replace the mains lead on my nokia ondigital box with a better quality one.This should prove quite straight forward but I've hit a stumbling block.
    I can't get into the case! Most of the screws are normal torx headed ones but the ones on the sides are torx but with a raised centre pin ( probably some sort of security measuree).
    Does anyone know what sort of fastener this is and if I can get a suitable driver for them??
  2. DaveP
    DaveP
    Try Maplin, I got a set for my sky+ box, they were £9.99.
    DaveP
  3. Mr.D
    Mr.D
    Jul 14, 2000
    11,167
    +1,209
    Ah its called in the trade "tamperproof torx" that'll be the one!
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Lik sang selll these for pence but Maplin, CPC, a market are your best bet!
  5. Mr.D
    Mr.D
    Jul 14, 2000
    11,167
    +1,209
    Thanks fellas
    A wee trip to maplins is in order tomorrow.
  6. Mr.D
    Mr.D
    Jul 14, 2000
    11,167
    +1,209
    Dang!.
    Just had another look and the screws in question may well not be tamperproof torx. Torx has 6 points but these only have 5!
    Any ideas?
    Failing this I'm going to have to buy a dremel and slice the case a bit.
  7. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    Pliers!!!
    However be careful I had a broken RF socket but the tuner went while it was in bits
    £70 to repair:(
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Still try maplin for a Tamper proof 5 point head screw remover. I gauruntee Snap-on Mac or Britool will make em!!!
  9. shodan
    shodan
    Dec 11, 2001
    11,595
    shoeburyness
    +6,522
    I believe B&Q do these tools... Or just try a trade electrical outlet. Thats where I got my torx 6 from for taking apart my nokia phones...
  10. Mr.D
    Mr.D
    Jul 14, 2000
    11,167
    +1,209
    I'll have a look fellas. Failing that its a dremel and a custom access panel operation!
  11. Mr.D
    Mr.D
    Jul 14, 2000
    11,167
    +1,209
    Got them!
    Just used a nice little flathead and bent the security pin out of the way. Took a bit of doing and I had to use a pair of pliers on the driver to give it enough welly but they are now out and the good thing is the case seems to hold together pretty well without them.
    Now just wait for new mains lead and solder it in when it arrives.
    Thanks for the advice.
