QUERY: parted magic on NAS
Discussion in 'Networking & NAS' started by andwan0, Sep 12, 2012.
  1. andwan0
    andwan0
    Aug 19, 2009
    10
    I have a NAS (DNS-320) which has one physical 500GB HDD.
    Is it possible to re-partition the HDD without wiping it (ie. retaining existing data). I can do this using "Parted Magic" live-CD on a laptop/PC, but not sure how to go about this with a NAS.
    Currently I have one full/large NTFS partition on my NAS, but I would like to create a FAT32 partition.
    Any help very much appreciated
  2. bubblegum57
    bubblegum57
    Jan 5, 2010
    1,902
    +302
    If you map it as a network drive, see if any partition tool sees it.
    IF. you try over a network, use a cable, even so, networks can just drop out, so it could muck it up.
  3. OmniBlade
    OmniBlade
    May 11, 2011
    4
    This a D-link sharecenter? According to google it formats its disks as some variation of the linux ext filesystems (probably ext3 or 4), not ntfs or fat32. You won't be repartitioning that over the network, you would need to take out the disks put them in a normal system and then run your parted magic disk on them, but I don't see how that would benefit you in any way.
  4. maf1970
    maf1970
    May 2, 2006
    2,118
    Aberdeen
    +305
    The NAS defaults to EXT3. However, if you read the user guide , there are options to allow it to be used by Apple etc.
    The question is though, why do you need a FAT32 partition ?
