Query: on Panasonic Tx36pl30
Discussion in 'General TV Discussions Forum' started by Discombobulate, May 6, 2003.
Tags:
  1. Discombobulate
    Discombobulate
    May 6, 2003
    7,506
    +614
    Just bought one of these from QED.
    Basically I have two queries about this tv:
    This is my first post so please no flaming if the answer is obvious.
    1) about the vertical position of the picture. The picture doesn't seem to be centered vertically. When I watch a program that fills the screen there seems to be more space at the top then at the bottom.
    Is there any way of changing this?
    The only settings I can find are for adjusting the angle of the picture.
    2) The default channel the TV turns on to is 1. I have a Tivo and DVD player connected. I don't watch tv via normal aerial.
    Is there a way to get the TV to turn on to either AV1 or AV4 by default?
    Any help appreciated.
  2. gbmitie
    gbmitie
    Apr 25, 2001
    1,139
    49
    republic of ireland now
    +61
    Do a search on here for your tv and u may get the answer there.
    It looks like u will have to access the set up menu and how to do that is here on this baord as well.
    I did a search for u but was not able to post link!!
    gb--
  3. Discombobulate
    Discombobulate
    May 6, 2003
    7,506
    +614
    Thanks.
    I have found the post about getting in to the service menu.
    No joy on the default of AV1 or AV4 though.
    Ah well. 1 out of 2 isn't that bad.
