Query on front Firewire ports...
Discussion in 'Desktop & Laptop Computers Forum' started by kelvin, Dec 31, 2004.
  1. kelvin
    kelvin
    Apr 22, 2002
    1,544
    Down South... (Bournemouth)
    +45
    I've just purchased a case with one IEEE 1394 port on the front (Coolermaster Centurion 5 :cool: ) but my current motherboard doesn't have built in firewire, and as such doesn't have the necessary pin headers for me to attatch the port to :(
    I do a fair amount of video editing and it would be highly useful if I could make use of the front port - is there any way I can do this without upgrading the motherboard? (i've only had it a few months :() I currently use a plug in PCI card for rear firewire inputs which has 3 external, and one internal sockets.
    Any advice greatly appreciated :)
    K.
  2. kelvin
    kelvin
    Apr 22, 2002
    1,544
    +45
    Forgive me if this is a stupid suggestion, but it would appear that an adaptor that converts the header pin connector to a regular male IEEE 1394 connector would be ideal as I could then simply connect the front port to the internal port on my PCI card.
    Does such a thing exist? :confused:
    K.
  3. kelvin
    kelvin
    Apr 22, 2002
    1,544
    +45
    Anyone? :)
  4. Seth Gecko
    Seth Gecko
    retired member
    Oct 9, 2004
    3,349
    83
    +193
    I don't know of an adaptor for what you are prosposing.
    Maybe try www.span.com - they do a lot of USB and Firewire stuff (may be best to give them a call) - slim chance that they would have what you require, but not impossible.
    However........if you get a Firewire card, you may be able to remove the port connector from your case and fit a cable from the card to the case (like a mini extension cable if you follow me) ?
  5. scrapbook
    scrapbook
    Jan 12, 2002
    7,115
    +527
    Sorry, don't know if i am having a blonde moment or not....never noticed that before on a firewire PCI card, but why has would it have an internal firewire port instead of the connection pins for a front port???
  6. Seth Gecko
    Seth Gecko
    retired member
    Oct 9, 2004
    3,349
    83
    +193
    Erm well mine has a standard internal connector and I use it to connect my DVD-Writer :) Bloody handy for me for sure !
    I've only seen it when it's a 4 port card personally, 3 port cards tend to only have external ports.
  7. scrapbook
    scrapbook
    Jan 12, 2002
    7,115
    +527
    Why wouldn't you connect to IDE on motherboard?
  8. scrapbook
    scrapbook
    Jan 12, 2002
    7,115
    +527
  9. kelvin
    kelvin
    Apr 22, 2002
    1,544
    +45
    I have this card :)
    Thanks ever so much for all of the replies - as I first thought, it appears i'm trying to do the impossible :( I may try Sadmuppet's (*snigger* ;)) suggestion, or I guess an alternative would be to go for one of the expansion bay's also mentioned - think i'd rather avoid that though...
    Thanks again, if anyone does come up with a solution to this though i'd like to know! :)
    K.
  10. scrapbook
    scrapbook
    Jan 12, 2002
    7,115
    +527
  11. kelvin
    kelvin
    Apr 22, 2002
    1,544
    +45
    Scrapbook, you are a star :D
    That's EXACTLY what I was after - just about to drop them a line regarding exporting! Fingers crossed :) WIll also hunt around a few UK suppliers to see if they sell a similar thing now I know that i'm not asking for something completely imaginary ;)
    K.
  12. kelvin
    kelvin
    Apr 22, 2002
    1,544
    +45
    Found a UK supplier here :cool:
    I guess the next obvious question, is can anywhere beat £7.50?! :p
  13. scrapbook
    scrapbook
    Jan 12, 2002
    7,115
    +527
    What the hell, just treat yourself for once!
  14. Seth Gecko
    Seth Gecko
    retired member
    Oct 9, 2004
    3,349
    83
    +193
    Indeed - if it does exactly what you need it to, just go for it :)
    Nice work Kelvin - interesting cable (I'll add the USA site though to my list cos they probably have other equally weird n wonderful things). :thumbsup:
  15. scrapbook
    scrapbook
    Jan 12, 2002
    7,115
    +527
    No problem!!!:hiya:
  16. jont
    jont
    Apr 8, 2002
    3,911
    near Aylesbury
    +410
  17. kelvin
    kelvin
    Apr 22, 2002
    1,544
    +45
    Thanks for the reply Jon :)
    I did actually order one in the end from the UK supplier I mentioned on page 1 ("Mr USB") - arrived quickly enough and does exactly what I needed it to :) Front firewire is now working perfectly! :smashin:
