Querieeee???
Discussion in 'Home Cinema Speakers' started by metnightshift, Feb 3, 2002.
  1. metnightshift
    metnightshift
    i have a 43 inch Sony projection television and
    A kenwood center speaker that I a place over the television
    I was told by someone that it would harm my Tv
    is there any truth to that
    thank you in advance
  2. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    Only speakers that are not magnetically shielded will harm a TV and centre speakers are always magnetically shielded.
    The tell tale sign is colour staining.
  3. lynx
    lynx
    Jan 20, 2002
    4,651
    It always rains.
    +302
    I was led to believe that RPtv's were immune to this. Is this the case?
  4. paiger
    paiger
    The magnetic field generated from most speakers will damage a CRT (cathode ray tube) if it's within 30cm. All centre speakers should be shielded to prevent this. I don't know what type of projectors RPTV's use but it may well be CRT, especially in high end models.
    S
  5. pointon
    pointon
    Oct 21, 2001
    1,381
    38
    Right behind you!!!
    +3
    In my experience RP TVs are not immune, but it doesn't matter because most center speakers (if not all speakers) nowadays are magnetically shielded.
  6. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Most RPTV use CRT and thus are allergic to magnetic interference.
    However, as mentioned the center should be shielded and therfore not harm the TV.
    Test:switch to an AV channel without an input being present (so you should get a blue screen). If you see the color changing to green or red/purple at some parts of the screen there is a magnetic field too close.
