Qucik question about which input to use
danmc_82
I have a Denon 2803 and marantz 5400 cd player. Im currently using a digital coaxial cable between the two. Just wondering would decent interconnects sound better or should I stay with digital. cheers
ps sorry if in wrong section
alexs2
It's a very easy one to answer.....try each in sucession and see which sounds best to your ears.
Sometimes you may find a player's on board DACs are better than the processor's,in which case analogue connects will perform best,and other times the processor's will be better.
rozzar
the DACs inside modest av amps are pretty yuck for music. Use the one inside the Marantz and use the white and red sockets as per normal.
Keep digital ins on av amps for DVD players et al :smashin:
LG CX Best Picture Settings
