I've just searched a little for VGA cables, and it's confused me a little. These are different places selling different cables (3 meters):
1) Lindy site are selling this for £20.80
Premium Gold S-VGA Monitor Cable (15HDM/15HDM), 3m
Gold Plated 15 Way HD Male to 15 Way HD Male
Designed for highest quality monitor applications, including CAD, DTP and Multimedia installations when preservation of display is a major consideration
Triple shielded 'low loss' coaxial cable, gold plated contacts and gold plated metal hoods assembled in accordance with 'EMC' compatible construction techniques
Incorporating secondary internal screening which provides a high degree of EMI shielding with clearer signal transmissions and minimum distortion
25 year warranty
2) rgbtosvideo site are selling this for £32.00
15 Way HD Male to 15 Way HD Male, 3m. Gold plated pins with high quality 75 ohm matched cable for video lines.
3) Joe @ MediaFactory are selling this at £48.80
VanDamme 15 Way HD Male to 15 Way HD Male, 3m. These cables use very high quality, flexible, installation grade OFC cable with close tolerance connectors, colour coded strain reliefs and gold plated pins where possible.
So there's a big jump in prices there - I mean where do you draw the line? Is there an obvious difference between these different ones? Any 'blind tests'?
