Quality of different DVD recorders
jetinder
In supermarkets and tv stores you see a lot of different firms making DVD recorders these are from supermarket own brands to ones made my panasonic etc.
What is the difference between the supermarket ones and ones made by panasonic etc ?
Is the recording and play back quality the same ?
Faust
Huge difference in build quality record quality and functions - go Panasonic if you can afford it you'll not be disappointed.
Gavtech
Administrator
A difference in use-ability and reliability are also major factors.
cooperda
The biggest thing to look out for is if the recorder records RGB rather than composite.
If it has built-in freeview even better.
And with newer models dual layer recording allowing 2 hours at high quality.
Cheers, Dave C.
AVForums Movies Podcast: We review Dune and ask which is the best decade for horror movies?
