Quality of Copying Sky+ recording to VHS
Discussion in 'Sky Digital TV Forum' started by malcom, Mar 20, 2002.
  1. malcom
    malcom
    Aug 25, 2001
    526
    +4
    How does the quality of a recording from a Sky+ hard drive to a standard VHS
    recorder compare to a normal VHS recording off air. In other words is there
    much of a quality loss when transferring Sky+ to VHS other than you would
    expect to see from the VHS format. Regards. malcom
  2. gringottsdirect
    gringottsdirect
    Jan 11, 2002
    2,912
    71
    50 Rue St Georges, Paris.
    +32
    malcom, there is no loss of quality recording from a Skyplus+ compared to recording from live Sky onto VHS.
    Having just replied to your other post, perhaps I should say, there is a slight loss of quality when comparing Skyplus+ to the copy onto a Philips DVD recorder, and a bit more loss when onto a Panasonic DVD recorder. No RGB input on Panasonic.
  3. malcom
    malcom
    Aug 25, 2001
    526
    +4
    Many thanks gringottsdirect. Your comment on the Philips and panasonic is much appreciated. Regards Malcom.
