quality Interlaced.VS Progressive WHO'S THE DADDY
Discussion in 'Blu-ray & DVD Players & Recorders' started by SLIM, Dec 24, 2004.
  1. SLIM
    SLIM
    Jan 1, 2004
    1,364
    38
    +17
    Ok Q WHO'S THE DADDY out of Interlaced./ Progressive when it come's right down to it :confused:.
    PS i have a Hitachi pd42 3000 :smashin:
  2. Ekko Star
    Ekko Star
    Mar 18, 2002
    6,613
    London
    +468
    If your plasma is a progressive panel (not too hot on your Hitachi I'm afraid) it is scaling whatever the input to display in a progressive fashion.
    So an interlaced source would be being converted by the panel into progressive. You could fire in a Progressive source direct to the panel so it doesn't have to do any scaling, in which case the source player would be doing all the hard work.
    Which would be better ? Depends really on if your plasma or the DVD had the better scaling as to what is best.
  3. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,565
    Edinburgh
    +1,265
    Are you not confusing scaling with deinterlacing. I know scaling comes into it too but it is irrelevant to the question that was asked about interlaced and progressive.
  4. AML
    AML
    Jul 22, 2004
    4,989
    Tokyo
    +228
    A progresive picture is just a little higher than an Interlaced picture.
    (ie 525i or 525p)
    The real quality lies in the resolution you use. If your DVD player only supports 525p then you wont really see any difference.
    Same for your TV.
    What you want is a DVD player like the New Denon 3910 and a Plasma or LCD TV that offers 720p or 1080i.
    THEN you can see which is better. Still the difference between 720p and 1080i is also hard to see.
    BUT its easy to see how much better they are than simply making 525i into progresive.
    Just because a DVD player is sold as "progresive" doesnt make it better than another player that is not.
  5. Ekko Star
    Ekko Star
    Mar 18, 2002
    6,613
    London
    +468
    Yes sorry I meant de-interlacing :blush:
    Depends if your display can de-interlace better than your player can fire out PS was what I was trying to get to.
    The relevance is I don't think it's a case of what is categorically better, which in most cases would be progressive, it is what marries best with your display and res capabilities.
    Q about the daddy, well that really is a difficult one !
