Quality Dvd-player For Plasma
Discussion in 'Plasma TVs' started by moku, Sep 27, 2004.
  1. moku
    moku
    Sep 19, 2004
    84
    Manchester
    Sorry guys for posting this message on this particular forum, but thought that some of you knowledgeable guys will have an answer to my problems:
    I'm on the market looking for a good quality DVD Recorder with or without a HDD to use with my new Fujitsu P42VHA30ES. The chosen machine must be capable of the following:
    1. Component Out to connect directly to Plasma
    2. Pal/NTSC Progressive Scan
    3. i-Link or DV in for my camcorder.
    I looked at the Panasonic DMR-E55HEBS and DMR-E85HEBS but both have no i-Link/DV in for my camcorder. The Sony RDR-GX7 would have been my preferred choice but unformately has no Progressive Scan despite having Components out .
    Any advice from you guys will be greatly appreciated.
    Moku.
  2. Blu Ray
    Blu Ray
    Jun 14, 2004
    495
    Chorley, Lancs
    +12
    What about the Sony RDR-HX900? About £500, it seems to have all of your requirements.
  3. moku
    moku
    Sep 19, 2004
    84
    Manchester
    Blu Ray,
    Thanks for that information. Will check out the Sony RDR-HX900 as suggested albeit £500 is a bit pricey. I'm also advised that the Toshiba RD-XS32 is the one to go for in terms of overall performance and value for money (approx. £380)
    Moku
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
