Quality £80-£100 VCR
Discussion in 'Digital TV & Video Players & Recorders' started by john87, Jun 16, 2002.
Tags:
  1. john87
    john87
    Needed mostly for recording.
    Long play is a must.
    What do you reccomend and what should I be looking out for (features etc.)?
    Oh yeah, and doesn't look cheap and nasty because it can't spoil the equipment rack ;)
  2. gges
    gges
    £80 to £100 IS cheap & nasty.
    You tight sod!
  3. Paul G
    Paul G
    Here's a more mature reply...
    Try Matsui. A friend of mine uses a £90 nicam model. For the price it gives a decent sharp picture performance and is easy to use.
  4. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,769
    7
    2
    167
    Birmingham, UK
    +10,673
    Some people want the Earth, and they want it delivered for £9.99.
    I don't think you're being realistic in your expectations.
  5. john87
    john87
    Not necassarily in terms of looks. Don't know about videos but the £100 Toshiba SD110E DVD player looks fairly decent.
    Hey I don't want to spend money on something I'm not too bothered about - just for recording (long play is needed as nearly everyone I know records in that mode and I will be swapping tapes with them). I don't have much money either.
    Thankyou for the reply I actually needed. Now I need to find out which Matsui it is.
    I think I am. Mostly for recording, long play (common, basic feature [i think]), not looking nasty... for £80-100 - that is realistic I'd say. You can get that sort of level for that price on a DVD player so surely you can on an out dated technology.
    I didn't ask for much really, I didn't even mention quality or build.
  6. gges
    gges
    Try a Panny NV-SJ220 (black or silver) Under a ton if you try hard enough! NV-FJ630 (black or silver) with Nicam for around £130 - £150.
    Supplied loads of these VCR's - complaints? - zilch! Faults - none!
    Highly recommended - as used by me!
    Regards - GGES.
  7. Paul G
    Paul G
    The Matsui vcr model no is VN 9720. (Hope it is still available).
    Yes I agree, Panasonic are definitely worth buying as well. I use a older mono one myself.
  8. AAA
    AAA
    SANYO VHRH792E- NICAM VHS,LP,....V GOOD MASHINE.
    £ 79, from EmpireDirect.co.uk.
    Beleive, this is a Bargain!!!
    Likely it is better than Matsui.
    Regards.
  9. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    have alook at this
    JVC HRJ595EK
    NICAM Stereo Video
    Hi-Fi VHS Stereo with NICAM, Video Plus+, NTSC Playback on PAL TV with Hi-Fi Audio, Auto Tune, Easy Picture Control, Easy Recording & Playback, Auto SP/LP Timer Recording, Variable Search, Skip Search and Shuttle Search, 4-Head System, Dual SCART Connectors with Satellite/PDC Compatibility, Power Save System10-Min. Power Backup
    From http://www.hed.co.uk/valuedirect/frontpage.asp?
    £100
    Pricerunner it to get the best deal but for £100 delivered it looks good.
